Author Topic: Single Point to Multi Point Communication  (Read 390 times)
Offline zero0dTopic starter
  • Country: hr
« on: March 19, 2021, 11:42:18 am »
Dear All,
i'm looking to design a single point to multi point communication with single wire referenced to GND ( fly-by ( daisy chain)  or tree (star) )  that works if possible with 1MHz.
Did somebody tried to build this and has a suggestion?
I think it would be great if we have a line or cable driver on booth host side and slave side, but i'm not Shure if this kind of IC exists ?
Also what do you think it is better to go with DC or AC coupled ?
The signal that will be transmitted from host to slave is  PWM like signal but can have pause between the 1MHz burst eg. __|▔|_|▔|_|▔|_______|▔|_|▔|_|▔|__
Best Regards.
