Author Topic: 12V 6V 19V Regulation from Battery for Flight Camera  (Read 1131 times)
Offline mechknollTopic starter
« on: February 03, 2016, 02:30:23 pm »
Good Day All,
I am integrating 3 camera systems in a large fixed wing UAV and am having trouble finding the perfect solution for power.  I have 3 cameras.  2 are powered by 6V and the last is 12V, then there is an onboard flight computer, it is an intel NUC and needs 19V.  Is there a simple way to use one Lithium Ion battery and regulate 4 outputs?  I have found several solutions but I want something that is VERY lightweight and reliable!  any help on this?
Offline KMoffett
Re: 12V 6V 19V Regulation from Battery for Flight Camera
« Reply #1 on: February 03, 2016, 08:14:41 pm »
What you want is a switch mode buck converter for each lower voltage...like: http://www.seeedstudio.com/depot/Adjustable-StepDown-DCDC-Converter-10V-17V18A-p-1717.html
Ken
