Author Topic: Avg. Power consumption calculation  (Read 930 times)
Offline ArCoNTopic starter
« on: February 04, 2019, 10:43:54 am »
Hi All  8)
Can any one help me with this.
I have a circuit that use:
30uA static
wake up 2 times/sec and uses 3.3mA for 10mS at idle
and it do some work 10 times/day and it uses 5mA for 5sec
i cant get it right, for some reason
i have a 1100mAh battery
I get around 100h in my calc and it is not right  :-\
Thanks
Offline Psi
Re: Avg. Power consumption calculation
« Reply #1 on: February 04, 2019, 11:03:06 am »
I got average total current draw of  98.894 uA
so 11123 hours
« Reply #2 on: February 04, 2019, 11:05:12 am »
Thanks Psi
Can you write how you did it?  ;D
Offline sleemanj
  • Professional tightwad.
« Reply #3 on: February 04, 2019, 11:09:09 am »
5mA for 5s is 0.0069 mAh, 10 times a day, divide by 24 hours 0.00289 mAh in an hour
3.3mA for 10mS is 9.1666666666667e-09 mAh, twice a second for an hour is 0.066 mAh in an hour
30uA for an hour is 0.03 mAh
Total 0.0988 mAh in an hour
I come up then with 11,000 hours (rounded :-))
I am probably wrong, I'm really bad at maths.
Offline Psi
« Reply #4 on: February 04, 2019, 11:14:29 am »
Here's the workings, excel file attached.
But i wouldn't trust this as correct unless someone else gets the same number.
(Edit, looks like sleemanj also got 0.0988 mAh  and round 11,000 hours )
« Last Edit: February 04, 2019, 11:24:28 am by Psi »
« Reply #5 on: February 04, 2019, 11:27:52 am »
Thanks a lot  ;D
Offline Psi
« Reply #6 on: February 04, 2019, 11:34:06 am »
No problem  :)
