One thing you can do is to get yourself a domain name and a web package, and then document your projects. Documentation is an important part of projects, and when you put it on a personal website, then you can put a link to it on your resume, so your potenial new employer can see what you've created.
EMI is also a big part of electronic design. You can learn about LISN, TEM-cells and do some EMC measurements on your circuits. Can you afford an oscilloscope, and something like the nanoVNA for measurements? For DIY projects, EMC is much less of a concern then for commercial products (which need to be certified, although I don't know the rules in Ethiopia). For DIY you don't need calibrated equipment, but doing some relative measurements, and the differences when you make changes to a layout, and documenting it all shows to an (future) employer that you're serious about the topics, and what skills are. Also add dates to your projects, so you can show progress in your skills over time.
I once built a gadget that used both the ADC of an uC, and used the same uC to multiplex a keyboard, and all build on perf (matrix) board. And although the circuit worked, interference from the keyboard multiplexing was so horrible that the ADC was barely usable. That was a good lesson for me.
