Author Topic: AVR Controlled LM317  (Read 18653 times)
Offline Richard Head
Re: AVR Controlled LM317
« Reply #25 on: April 29, 2014, 11:57:11 am »
I have recently used a 10-bit DAC instead of a PWM. It works like a dream with no calibration required. Unfortunately the DAC is damn expensive. Luckily this application can afford it.
I wonder if they"ll ever have onboard DAC's in microcontrollers? I love using them, so precise.
Offline dannyf
« Reply #26 on: April 29, 2014, 12:22:49 pm »
Wonder no more - tons of them out there.
« Reply #27 on: April 29, 2014, 01:37:51 pm »
dannyf
Now you've got me looking at the TI micros with onboard DAC's. I never knew!
Offline dannyf
« Reply #28 on: April 29, 2014, 02:01:38 pm »
Not just TI, other folks too: Freescale is top notch when it comes mixed signal mcus (Silabs great on ADC). STM32F3 is another option. Even some of the lowly PICs now have DAC (or Vref generator with an output pin).
Offline miguelvp
« Reply #29 on: April 30, 2014, 05:48:28 am »
And Cypress, don't forget about them, even with programmable analog blocks.
Offline Lizerd
    • www.lizerd.se
« Reply #30 on: April 30, 2014, 06:04:44 am »
Almost all mid-high end STM32 has 12bit DAC.
Even quite a lot of the low-ends have 12bit DAC
update on my lab psu, read more at www.lizerd.se/?p=893
« Last Edit: April 30, 2014, 06:06:26 am by Lizerd »
Offline themacman33Topic starter
« Reply #31 on: August 10, 2014, 04:52:49 pm »
After a brief break, I have decided to just use a lm2576-adj with i2c from an AVR to control a SMPS. I find that it will be easier to implement, lower noise, and more accurate.
Lizerd, that looks like a really neat project, I'll take a look at it!
</Mac>
Offline dannyf
« Reply #32 on: August 10, 2014, 10:26:03 pm »
Nicely done.
The same principle applies to a linear regulator-based power supply. Switchers do have the advantage of being more efficient, making them more compact.
