Author Topic: Single IC for Power Line Communication?  (Read 1753 times)
Offline emqxTopic starter
« on: June 28, 2019, 05:48:57 pm »
I am looking for a simple single integrated-circuit solution for home automation (primarily, switching of lights and ACs and, dimmer control for fan).
What I need is a single IC transceiver (line-driver + modem + controller) that can directly interface with 230V AC line.
The key retirement is that each PCB should be small enough to fit in sockets and switches and low cost and BOM.
Is there any product available out there?
Offline erikka
Re: Single IC for Power Line Communication?
« Reply #2 on: June 28, 2019, 08:01:06 pm »
KNX is max 45volt. Not sure that is sufficient for connection to mains
Offline SiliconWizard
