It seems like
tme.eu have a very small collection of axial capacitors. Only 85C rated ones, and from SR Passives. Anyone know about SR Passives?
They are for a weldingmachine that is acting up (Migatronic Automig 200) - I'll check the power resistors, diodes and similar "easy to test components". The small trannies looks good visually. Other things to check now I got it on the table?
Forgot to mention. When the main relay is energized, the gasvalve clicks/buzz at a rather high rate, and it gets to hot to touch in seconds. The valve it self a 24VAC one. What could make that happen?
