I've had this idea for a little while, and I'm not sure if there are any huge pitfalls I'm missing that would make doing this a bad idea.
I've wanted a tiny little function generator, and some of the Analog Devices DDS chips seem like a perfect solution.
For instance, I've looked into the
AD9834 and it seems like a pretty cool little chip that could do sine, square and triangle waves. It could be controlled with a simple microcontroller setup which would have a display and some buttons or an encoder with a button for control.
The downsides I can forsee are:
- It's kinda expensive, $13/chip in low quantities.
- 75MHz maximum frequency, I think it'd be perfectly usable, but it could be a little low
- Digital amplitude control could be difficult - any suggestions for this?
Other than these downsides, I feel like it would be a fun idea to attempt, and could be really fun to try out small-scale manufacturing and selling it on Tindie if I'm able to make it work well enough.
Thoughts?
