I first saw an idea like that with the TDA4601 and TDA4605 controllers. Switching transistor current is simulated by a capacitor being charged via a resistor from the HVDC while the transistor is on and fully discharged when the transistor is off. The controllers operated in transition mode, never CCM.
I guess the idea is to avoid the need for a CS resistor which would be great advantage in high current designs.
