Author Topic: CMOS Image Sensor  (Read 843 times)
Offline deslozTopic starter
  • Country: br
CMOS Image Sensor
« on: April 30, 2019, 05:15:55 pm »
Hello.  Is it possible to read only from one line in a CMOS sensor, in order to increase the frame rate (or line rate)?
For example, using this sensor from ON Semi , https://www.onsemi.com/pub/Collateral/AR0134CS-D.PDF.
How can I read only the central line, or a group of lines in the center of the sensor?  Thank you.
Offline Bassman59
  • Yes, I do this for a living
Re: CMOS Image Sensor
« Reply #1 on: April 30, 2019, 06:58:07 pm »
Page 3 of the datasheet you posted:
• Window Control
Configurable window size and blanking times allow a wide range of resolutions and frame rates. Digital binning and skipping modes are supported, as are vertical and horizontal mirror operations.
Which means that you have to set some of the internal registers via I2C to control the region of interest. Those registers are not documented in the data sheet, so you should check ON's website for it.
