Hey y'all, I just finished assembling the first prototype of an idea I've had bopping around in my head for a while. It's probably overkill, but I had fun making it. Recently I've seen folks talking about 4-Wire measurements and the best way to do them, which sent me down a rabbit hole looking at various styles of "kelvin clips", many with coaxial cabling for each input. I really like this style, but I didn't really like the way I saw it being implemented; usually by people stripping back the coax, twisting the braid, and soldering it to a board next to the center conductor. It works perfectly fine that way of course, but if you want to use those clips anywhere else it's not really viable. So I designed my own board with four BNC PCB connectors to connect to the individual force & sense leads and tie all the shields together, without having to butcher the BNC leads that come on those kelvin clips, so if you want to use them on other gear, you can.
At first, I was hoping to make it all on one board, but the size of the BNC connectors I wanted to use, this didn't really work out. I was also a bit concerned with board flex when using one board, so I settled on two stacked boards. To connect the boards, I found some nice gold plated brass 4-Pin .1" headers from Mill-Max that were the perfect height for the 5mm board clearance I wanted. The board is really simple, both are four layer boards so I can keep force & sense on different layers and maintain shielding all the way up to the banana jack, with vias around the periphery to tie the ground fill on every layer together (this is mostly for looks though, as the ground layers are tied together well enough from 24 plated through holes used by the BNC connectors, pin headers, and the mounting holes). I used KiCad for the board layout, and I had to make my own footprints for everything which luckily seems to have turned out perfectly.
If y'all are interested, I'll upload all the files to github so you can build one yourself, but be wary, it's a bit of a pain to solder, so you'll definitely want to get your hot plates or pre-heaters ready. I'd also really like to order a blue mask version with ENIG and some graphics maybe, so if y'all are
really interested, I'd be open to running a small group-buy to offset the fanciness cost.
Photos below, but for the high res ones, here's a link to an imgur album I made, which also has some more commentary! Thanks for reading!
https://imgur.com/gallery/B6nNp7mEDIT 22/09/2021: Created a public github repository! Includes KiCad project files, gerbers, and bill of materials.
https://github.com/figurativelythedevil/Banana-Jack-to-Coax-Adapter
