Author Topic: TrueTime XL-AK 600-00 : Options  (Read 494 times)
Offline comsec22Topic starter
« on: May 14, 2023, 01:35:40 pm »
I found the right pin to inject an external 10 Mhz standard (pin F + Gnd) moving JP6 by 2-3 to 2-1..
when i try to give serial command F07 : ERROR 05 NO SUCH FUNCTION.
External Oscillator Enable, is one of the several options, is it any possible way to enable ?
Perhaps is the firmware in eeprom..
F18 : TRUETIME XL     ACE3 sys ver 029 GPS-XL V1.046   182-6064v007
Any supports is welcome.
Offline barshatriplee
  • Country: bd
Re: TrueTime XL-AK 600-00 : Options
« Reply #1 on: May 14, 2023, 02:31:52 pm »
It's possible that the F07 command is not available on your Tektronix TDS 524a oscilloscope, which is why you are getting the "ERROR 05 NO SUCH FUNCTION" message. I think you should contact Tektronix technical support: https://www.tek.com/en/support/contact-technical-support
« Reply #2 on: May 14, 2023, 07:40:18 pm »
barshatriplee..
The topic is related to a TrueTime GPS not to a Tektroniks scope..
