Author Topic: Relay Contacts - where to find?  (Read 615 times)
Offline AvrHornetTopic starter
« on: May 14, 2023, 09:32:14 pm »
Hello,
First post here and hope to contribute as a hardware engineer of 20+ years. I have a design that needs a small copper strip with a contact rivet on one end - the same that you see in a relay. The middle pole that flexes between the two contacts. If my project works out as planned I would need a few thousands per year so cutting apart a relay would not be feasible :)
Does anyone know where I could find something like this? I am attaching a pic showing the electrical contact I am looking for. Thanks in advance!!!
Tom
Offline uer166
Re: Relay Contacts - where to find?
« Reply #1 on: May 14, 2023, 09:45:33 pm »
Definitely need to look at wholesalers, here is the first link I found: https://www.alibaba.com/product-detail/Switch-Relay-Electric-Electrical-Agni-Silver_60401957286.html?spm=a2700.galleryofferlist.normal_offer.d_title.369083affqhUAF
I'm sure it can be customized to whatever you need as well.
Offline Someone
    • send complaints here
« Reply #3 on: May 14, 2023, 11:02:05 pm »
"[open] leaf switch"
