Thanks nanofrog, I've updated my profile. It was some of your other posts that convinced me to buy from canvu0_0. I ended up purchasing my mat from this seller a couple months ago. Everything was great except the stud (upper) detached from the lower part (I believe it is the ones that are pressed on with a tool) not the ones with the spiky ends. I'll probably get these screw on one ones:
http://media.digikey.com/photos/Desco%20Photos/09864.jpg
Sad to hear about the connector coming off. The mat I purchased from him came with a 4 prong type I had to install myself. Not a fan of this type, but they do work.
So like you, I was drawn to that Desco screw type you linked, and they're great to use IME.
Easy to install, and they've stayed put for me (I'm not kicking the ground wire though). Not cheap if that's all you get due to shipping, but they make great filler items on orders if you can do it that way.
I was thinking about getting these on eBay:
http://www.ebay.com/itm/ESD-Safe-Anti-Static-Wrist-Strap-6ft-Ground-cord-METAL-WRISTBAND-10MM-/261170230460?pt=LH_DefaultDomain_0&hash=item3ccef574bc
Is there any significant advantage of spending the extra money and buying the Desco brand ones? I see that the Desco snaps are machined and the one on eBay is pressed however I don't think this alone would be worth the extra cost...
IME, the wrist straps I've gotten from unknown sources tend to be child sized. I'm over 6ft tall, so they tend not to fit properly, if at all (usually don't have enough strap to latch down in the buckle).
Desco offers different sizes for their wrist bands, and the large I linked fits. The machined sockets have better electrical contact (intermittent contact is a problem this helps to solve), and can be worth having. 3M also offers decent quality ESD products. Do note the different quality levels, as they have multiples to meet different budgets (even disposable meant for field service).
I use an ESD workstation monitor (
Desco Jewel Continuous Workstation Monitor) I got off of eBay for a very good price (I'm fond of used gear that's been well cared for, and especially NOS
). This particular unit connects directly to the 10mm snap connector on the mat itself, so it eliminates a wire.
Found a
Desco 19228 on eBay that would be worth trying to get (about to expire w/ no bids, so it may get relisted).
They also have much better ground wires to the wrist straps (heavier, not as likely to come off IME).
Though the one on eBay mentions that the upper surface is coated with insulated paint, is this sufficient ?
So long as you don't scrape it against things that will wear through it, Yes. And if you get some scuffs and scrapes, you can touch it up with some Testors model paint or something.
Another trick, is to attach it to your bicep (Dave did this in the uCurrent video where he assembled one on camera IIRC). Frees up your hands, and you don't drag it across anything.
