An analog gauge has a full-scale current/voltage and the shunt is whatever resistance you need to have the meter's full-scale voltage at the desired full-scale current.
Use a low-current/voltage power source, step it up slowly until you get full deflection, subtract that current from your max range, divide the full-scale current by the remainder of the current, that gives you your shunt resistance.
