I guess I'll start with to goals of the project and then get on to where I'm at and see if anyone is willing to help point me in a direction. The goal is to create a hand held housing that will contain a lithium battery pack, charging circuit, and a DC to AC constant current power source to run a UV-C germicidal fluorescent tube. The housing will be 3D printed and the tube/bulb will be placed behind a piece of UV bandpass filter glass. Since I know someone is sure to ask what the reasoning for creating this is, I found out my mother has started collecting UV reactive rocks and minerals, I wasn't even aware that was a thing but turns out there a quite a few that do. Currently she is stuck using the cheap purple/UV LED flashlights, so for her birthday in January I wanted to create an absolutely over the top UV light for her that wouldn't also spray tons of blue and purple light as well as the UV wavelengths.
Where I'm at now, I'm not a electrical engineer by any means but I have a good knowledge of circuits and all the physical tools needed to complete this project. The current plan is to breadboard the design first, and once I know it works I will do a one off etched single sided PCB since I don't expect to have to make multiple boards. I normally stick to modifying existing designs, so this will be the first from scratch power supply I would be making for a project like this. I know the bulb I want to use is the Philips TUV PL-S 13W, It is a .29A tube with a nominal voltage of 56v. If all else fails I can buy a 150w car inverter and rip it apart for the guts and combine it with a ballast I found online but that would end up being very bulky and i would like to create a single circuit board to go from the lithium straight to the correct AC output for the UV Tube.
The issue I'm running into is finding any sort of modern design of a supply system that can convert from a lithium battery pack to AC constant current. I found a very old design using a BD243C transistor and a handful of resistors/caps along with a custom wound 2P1S transformer, however had the drawback of the transistor would blow up if turned on with no load and the design was over 20 years old. I'm not asking for someone to design a circuit for me, but rather a pointer to a transistor or concept that is capable of creating a power supply to run the tube. If anyone is willing to get me started in a direction I would appreciate it.
