Author Topic: ATTEN OSCILLOSCOPES and EASYSCOPE  (Read 6392 times)
Offline MrsRTopic starter
« on: July 01, 2012, 07:09:37 pm »
Hi!
I have read some posts about the USB driver for ATTEN scopes. I have been after a 64bit driver for some time and ATTEN has sent me this address
http://www.atten.eu/media/catalog/product/pdf/64-bitSigned.zip
I have down loaded it but haven't tried it as my scope is in for repair hope this Helps :D
ALL THE BEST
Rachael
P.S. If someone uses this Driver can you put a report on it,eg. if it works OK! if NOT! any problems.
« Last Edit: July 02, 2012, 05:38:19 pm by MrsR »
Offline ipereira57
Re: ATTEN OSCILLOSCOPES and EASYSCOPE
« Reply #1 on: January 27, 2013, 04:19:56 pm »
Hi. I download the file that you give, but nothing. When I  push connect appear "Linked Fail"
« Reply #2 on: February 08, 2013, 11:29:27 pm »
I just clicked on the address I posted and it worked fine.
GIVE IT AGO
Rachael :-+
Offline Longtimetech
« Reply #3 on: February 09, 2013, 11:52:17 pm »
I assume you ran the downloaded file and it installed properly.  Now maybe the new program needs configured as to what connection method you want to use to link to the scope.  Just a hunch.
Offline mickytech
« Reply #4 on: March 06, 2013, 10:41:11 am »
tried to use this usb driver and it failed , back to drawing board   |O
Offline unexpectedly
« Reply #5 on: June 16, 2013, 12:35:30 am »
That link worked for me, thanks. Win 7 x64 Atten ADS1062C  The drivers from the included CD-ROM as well as from Atten China page did not work.
I just bought the Easyscope from http://www.atten.eu/ but it must take them a while to add it to my downloads...? Trying to connect an Arduino to a DRO scale...
Thanks!
Chris
