Author Topic: BAV99 low-voltage IV curve  (Read 1905 times)
Offline matthuszaghTopic starter
« on: December 04, 2022, 06:00:34 pm »
I have an application for which I wanted to know the IV curve of the BAV99 at low voltages. I measured a single diode from the pair in the forward direction on my HP 4145A for 200 values between 0.001 and 0.2 V. I think these results may also be useful to others, so I'm posting the plot. The blue curve is just the calculated static resistance, i.e., V/I.
« Last Edit: December 04, 2022, 06:02:22 pm by matthuszagh »
The following users thanked this post: thm_w, doktor pyta, gamalot
Online TimFox
Re: BAV99 low-voltage IV curve
« Reply #1 on: December 04, 2022, 07:33:18 pm »
Another curve that might be more useful for some applications is the "dynamic resistance" dV/dI.
Offline David Hess
  • DavidH
« Reply #2 on: December 04, 2022, 07:57:47 pm »
I would like to see a small signal transistor like the 2N3904 emitter-base and collector-base junction also for comparison.
Offline mawyatt
« Reply #3 on: December 04, 2022, 08:34:45 pm »
Nice!!
Maybe extend the voltage range to 0.5 or 0.6V forward biased, and also the reverse biased junction capacitance would be useful to "see" if the OP has the time.
Best,
~Wyatt Labs by Mike~
Online TimFox
« Reply #4 on: December 04, 2022, 08:36:49 pm »
For some applications, it is useful to see the dynamic resistance as the voltage goes through the origin (from slightly positive to slightly negative).
Near zero bias, the junction capacitance is maximum, and the dynamic resistance is finite.
Offline Kleinstein
« Reply #5 on: December 04, 2022, 09:42:09 pm »
The fast diodes are usually rather high in leakage and also tend to have a relatively low differential resistance. The small signal transitor (unless a gold doped one) tend to be much lower leakage and higher resistance.
I think the resistor should not go down again for the very low votlages. The expected form is more like increasing resistance down to a bit in the reverse direction and than more like constant for a while.
So the drop in the curve could be offset or maybe extra leakage due to light.
« Reply #6 on: December 06, 2022, 01:49:24 am »
Here are some more measurements to show more of the range. I've kept the ranges separate, because it makes it easier to read off values from the plot. Note that not all scales are the same. In the reverse plot, I swept in the reverse direction from 0.1 to -0.1 V.
The following users thanked this post: doktor pyta, 42Khz
« Reply #7 on: December 06, 2022, 01:50:15 am »
more plots
The following users thanked this post: 42Khz
« Reply #8 on: December 06, 2022, 01:51:09 am »
all raw data (except reverse sweep).
The following users thanked this post: mawyatt
« Reply #9 on: December 06, 2022, 01:53:37 am »
I'll keep this setup for a day or two, in case people want me to try anything else. I'll try to get around to measuring a 2N3904 for comparison.
I also have a Keithley 617 electrometer, in case people want to see a comparison with that. I use that with a much shorter triaxial cable, but the same HP 16058A test fixture.
« Last Edit: December 06, 2022, 01:56:02 am by matthuszagh »
Offline dmendesf
  • Country: br
« Reply #10 on: December 09, 2022, 09:15:00 am »
 Could you please plot IV graphics for an IR led? They seem very steep...
« Reply #11 on: December 16, 2022, 02:09:26 pm »
Are you saying the BAV99 IV curve appears very steep, or an IR LED? I don't think I have an IR LED on hand, but if you send me one I can measure it and share the results.
Offline David Hess
  • DavidH
« Reply #12 on: December 16, 2022, 02:40:20 pm »
Here are the results of various diode curves that Robert Pease measured.
The slope of the curve is "conductance" with high conductance diodes having a steeper slope.  Common transistor base-emitter junctions have an ideal 60 millivolts per decade of current but most silicon diodes are inferior because they are optimized for other things, although even the low leakage diode he tested was not as good as a transistor base-emitter junction.  Schottky diodes come in different types with different values of conductance; HP had different categories for low, medium, and high conductance.
He also mentions that red LEDs can have very low forward currents, like 1 picoamp at 0.6 volts forward voltage which is useful in some circuits.
« Last Edit: December 16, 2022, 02:45:04 pm by David Hess »
The following users thanked this post: matthuszagh
