Quote from: I_may_be_drunk_right_now on March 17, 2014, 02:32:02 amI don't think you've found too many power supplies that use a full-wave rectifier with a center-tapped transformer. Study it out, only two diodes are ever working here, and your output ripple is 60Hz, or 50Hz ... The other two diodes are just reverse biased all the time.I mean if you're using that part because it's all you have, great, but you should understand what is going on here.Perhaps you are referring to the classic voltage doubler/rectifier circuit that feeds two stacked capacitors on the input of old switching supplies?Or maybe two separate windings with each its own full-wave rectifier?I do think you're drunk It's two separate full wave rectifier circuits, with a common ground. Perfectly OK for the OP's needs.
Quote from: I_may_be_drunk_right_now on March 16, 2014, 01:19:21 amI don't think you've found too many power supplies that use a full-wave rectifier with a center-tapped transformer. Study it out, only two diodes are ever working here, and your output ripple is 60Hz, or 50Hz ... The other two diodes are just reverse biased all the time.I mean if you're using that part because it's all you have, great, but you should understand what is going on here.Perhaps you are referring to the classic voltage doubler/rectifier circuit that feeds two stacked capacitors on the input of old switching supplies?Or maybe two separate windings with each its own full-wave rectifier?What I've basically built is a slight variation of various other designs.Like thishttp://cdn.head-fi.org/e/e4/900x900px-LL-e431d7c1_317_337Schematic.pngOr this... (but with a purpose built bridge rectifier instead of four individual diodes)http://cdn.head-fi.org/0/08/900x900px-LL-08345efb_SP-2-LMSCH.jpegor thishttp://sound.westhost.com/p44-fig1.gifIt seems to work fine. I've checked the outputs of the + and - pins of the rectifier with my scope (before adding the smoothing caps) and it looks exactly like the examples I've found.The + pin gives me exactly what this attachment looks like and the - pin is just the mirror image.
Quote from: dentaku on March 17, 2014, 01:40:23 pmQuote from: I_may_be_drunk_right_now on March 16, 2014, 01:19:21 amI don't think you've found too many power supplies that use a full-wave rectifier with a center-tapped transformer. Study it out, only two diodes are ever working here, and your output ripple is 60Hz, or 50Hz ... The other two diodes are just reverse biased all the time.I mean if you're using that part because it's all you have, great, but you should understand what is going on here.Perhaps you are referring to the classic voltage doubler/rectifier circuit that feeds two stacked capacitors on the input of old switching supplies?Or maybe two separate windings with each its own full-wave rectifier?What I've basically built is a slight variation of various other designs.Like thishttp://cdn.head-fi.org/e/e4/900x900px-LL-e431d7c1_317_337Schematic.pngOr this... (but with a purpose built bridge rectifier instead of four individual diodes)http://cdn.head-fi.org/0/08/900x900px-LL-08345efb_SP-2-LMSCH.jpegor thishttp://sound.westhost.com/p44-fig1.gifIt seems to work fine. I've checked the outputs of the + and - pins of the rectifier with my scope (before adding the smoothing caps) and it looks exactly like the examples I've found.The + pin gives me exactly what this attachment looks like and the - pin is just the mirror image.Of course it would, but at what frequency? Or is your schematic wrong?You're just copying stuff. There is only two diodes ever working here.
