This is all you need. Instead of a switch, you can use a logic source and single gate driver IC, and whatever value gate resistors you wish. The logic and supply must be isolated, that is all.
Note that some snubber or protection circuitry may be desirable, especially with quick switching times and around inductive loads (e.g., AC line inductance). You could use a voltage peak, or dV/dt, type snubber per transistor, or An AC variation on either, connected from drain to drain; or just a boring R+C or MOV.
