Author Topic: Benefits of transformer output for lab. frequency reference?  (Read 734 times)
Offline IllusionistTopic starter
  • Why is the rum gone?
« on: September 08, 2019, 06:46:09 pm »
I'm designing the output stage for my 10MHz GPSDO. So far I've narrowed down the sine wave output op amps to either AD8052 or LM7171 (mostly because I have some of both).
On some designs I've seen on the 'net, the output is transformer coupled for 'isolation' (that's all that was said about it). I have some Minicircuits transformers that would suit (T1-1T-KK81+), but I don't really understand what the benefits and drawbacks are. Other than DC isolation of course, with the drawback that I then have to somehow insulate the output sockets from the (grounded) metal panel of my enclosure. Is there anything else I should know? Is it really useful? I'll be using the GPSDO as a reference to the usual suspects in my home lab.
Also, where would I put ESD protection (CM1213A I think)... on the primary or secondary side?
« Last Edit: September 08, 2019, 07:12:53 pm by Illusionist »
Agilent 34410A, GW Instek 8251A, Thurlby 1905A, Siglent DS1104X-E(unlocked), SDG1032X(unlocked), Micsig DP10013 MX, LeCroy PP008 500MHz Probes, Fluke 179
Offline edpalmer42
Re: Benefits of transformer output for lab. frequency reference?
« Reply #1 on: September 08, 2019, 10:45:14 pm »
In addition to the DC isolation you mentioned, transformer outputs break low-frequency ground loops (typically mains frequency) which can mess up low level or high precision measurements.
One thing to remember is that you should still have a parallel resistor/capacitor path between the shield and ground.  The capacitor gives you high frequency coupling to ground so that the shield can still act as a shield.  The resistor gives you a high value DC ground path to bleed off any charge on the shield.  I don't know if there is any concensus on what the component values should be.  One Rb standard that I know of (Efratom FRT) omitted the resistor and used 6n8 capacitors.
If you use BNC connectors, it's really easy to find cheap isolated, panel mount, female connectors.
Ed
« Reply #2 on: September 09, 2019, 08:18:11 am »
Thank you for that. I'll stick with the transformers.
Yes, a quick search turned up some isolated BNC connectors. In fact I think I even have some, somewhere.
