Author Topic: Help identifying 5 & 7 pin connectors  (Read 2958 times)
Offline David_AVDTopic starter
« on: April 16, 2014, 05:10:37 am »
Does anyone know off the top of their head what brand / series these connectors are?
They mount from the front (rear nut) and have a male threaded bush that the mating plug (or dust cap) screws onto.
I can't see any markings or clearly get to the back of them, except to see that they have solder cup terminals.
Offline miguelvp
Re: Help identifying 5 & 7 pin connectors
« Reply #1 on: April 16, 2014, 05:47:14 am »
They look like DIN connectors close to 240 degrees (60 degrees between pins) but nope. The other one is 72 degrees apart strange for DINs
What are they attached to?
« Reply #2 on: April 16, 2014, 06:03:18 am »
Definitely not DIN sockets.  They are part of some custom equipment that a client needs new cables for.
Offline pickle9000
« Reply #3 on: April 16, 2014, 06:39:15 am »
eco mate by amphenol maybe?
Do you have a side image?
« Reply #4 on: April 16, 2014, 06:44:19 am »
Just looked up the Amphenol Eco-mate.  Not it, but thanks for the suggestion.
No other pictures sorry.
Might have to try and track down who made the item and see if they will tell us what they are.
Offline miguelvp
« Reply #5 on: April 16, 2014, 06:44:45 am »
Would have helped if you mentioned it was a waterproof system or even aviation.
Do these match?
If they do, they are IP68 5 pins/7pins waterproof dustproof connectors
Offline amyk
« Reply #6 on: April 16, 2014, 12:18:52 pm »
« Reply #7 on: April 17, 2014, 08:22:30 am »
Do these match?
The connectors are not on a piece of mission critical gear.  I have no idea why they chose them originally.
Part of the issue is that I have only seen the plug in a not very close-up photo.
The second picture looks like a match for the socket.  I'll go from there.  Thank you.  :-)
Offline miguelvp
« Reply #8 on: April 18, 2014, 07:07:18 pm »
« Last Edit: April 18, 2014, 07:10:33 pm by miguelvp »
