Author Topic: TVS selection guide - Is it wrong, or i am not comprehending?  (Read 610 times)
Offline eTobeyTopic starter
  • Virtual Features for the SDS800XHD -> My website
    • Virtual feature script
« on: January 04, 2024, 02:56:53 pm »
In the Manual it states:
"For example, if the protected line operates at 5 V nominal with a maximum variance up to 7 V, ensure that the VRWM is 7 V or greater."
So if i choose a Diode with 7V Vrwm, then the diode starts to really conduct just from lets say 7.5V in a ESD event. So that gives me a voltage, that exceeds the maximum values of 7V, wouldnt it?
« Last Edit: January 04, 2024, 03:52:00 pm by eTobey »
"Sometimes, after talking with a person, you want to pet a dog, wave at a monkey, and take off your hat to an elephant."(Maxim Gorki)
SDS800X HD bugs/issues/workarounds (Updated 17. Feb. 2025)
Offline tooki
Re: TVS selection guide - Is it wrong, or i am not comprehending?
« Reply #1 on: January 04, 2024, 03:37:07 pm »
Sorry, what’s confusing you here?
They’re simply saying “even if the nominal voltage (=Nennspannung) is 5V, if its signal normally can reach 7V even temporarily, then choose a diode with Vrwm above 7V”.
The “variance” they mention doesn’t mean the absolute maximum value from the component datasheet; if your signal exceeded that, it would fry the chip even without ESD. A 7V signal would already be far outside the 5.5V absolute maximum of typical TTL, for example, but well within 4000-series CMOS logic.
So if you’re protecting TTL with an absolute maximum of 5.5V, you’d need to choose a 5V TVS.
« Last Edit: January 04, 2024, 03:40:05 pm by tooki »
Offline sparkydog
« Reply #2 on: January 04, 2024, 06:28:24 pm »
As noted, "maximum variance" is talking about your maximum normal operation voltage, as in, you don't want the TVS mucking with this. A TVS should never conduct under normal input voltage. A TVS is not intended to be used as a voltage regulator, and doing so can damage it prematurely because they are not meant to conduct continuously.
(That said, note that it's not unusual to use a TVS to "eat" inductor spikes e.g. from relays / solenoids. Although that is "normal operation", it isn't continuous conduction because the spikes are brief.)
Uh... if your nominal voltage is 5V and 5.5V releases the magic smoke, I don't think a TVS is going to work. Now, to be sure, SMBJ is a commodity TVS and maybe more "sensitive" TVSs exist, but a 5V nominal SMBJ has a breakdown voltage (VBR) rating of  6.40V - 7.00V and a maximum clamping voltage (VC) of 9.2V. Say goodbye to your TTL.
Personally, if I'm using a TVS to protect something, I try to arrange for its VC to be around 60-70% the max voltage rating of the device it's protecting. (For example, I have designs that use SMBJ18s with components rated for 48V.)
