Author Topic: PT2262 RF ENCODER  (Read 1640 times)
Offline stern0m1Topic starter
PT2262 RF ENCODER
« on: February 13, 2020, 09:24:24 pm »
Is there something similar to the PT2262 Encoder that the address bits are randomly set by the manufacturer of the chip? Requiring no programming
http://www.princeton.com.tw/Portals/0/Product/PT2262_5.pdf
Thanks!
« Last Edit: February 13, 2020, 09:53:06 pm by stern0m1 »
Offline floobydust
Re: PT2262 RF ENCODER
« Reply #1 on: February 13, 2020, 10:55:47 pm »
One alternative is PT2272 or Holtek HT12E or EV1527 (learning code) or Holtek HT6P20.
Most of the new tech IC's are code-learning.  That PT2262 IC is low security because it uses fixed code and vulnerable to copycat attacks.
Linx sells the complete remotes, receivers, IC's too from Digikey.
« Reply #2 on: February 13, 2020, 11:37:47 pm »
Thank you for the information.
All of these require, in one shape or another setting the "address". No one makes an encoder with an option for the "address" to be just randomly set by the ic manufacturer?
Offline floobydust
« Reply #3 on: February 14, 2020, 01:05:02 am »
EV1527 has a factory 20-bit address (1,048,576) pre-programmed I think. It's just a button press on the receiver to learn and accept this. This IC part is in many eBay little remote boards.
« Reply #4 on: February 14, 2020, 09:56:48 am »
Which chip is used to decode ev1527?
Thanks
Offline ebclr
« Reply #5 on: February 14, 2020, 06:51:56 pm »
« Reply #6 on: February 14, 2020, 10:07:48 pm »
How do you set it to" learn"  the preprogrammed address in the 1527?
The datasheets are not really clear.
Thanks
