Bob,
I designed a solar MPPT charger, designed for lead acid batteries, that might be a fit. You'd have to create the shelters and - most importantly - size the panel and batteries to match you load. I think lead acid batteries are best for most outdoor applications because of their operating temperature range.
https://www.tindie.com/products/globoy/mppt-solar-charger-for-intelligent-devices/?pt=ac_prod_searchEven if my charger isn't of interest, you should read the appendix in its manual that talks about sizing the system. I think most people tend to underestimate the size of battery and panels they will need for reliable 24/7 operation - especially in winter which, in the northern hemisphere, is a very low solar production time.
0.3A @ 5V -> 1.5W x 24 hours means you're going to need about 36W of energy per day. Since your camera is powered from a 5V supply then you'd have a DC-DC stepping down the nom 12V to 5V. It has an efficiency rating so if you assume that to be 90% then you'll need about 3.3A from the 12V battery over the course of a day. If you didn't want to fully discharge your battery to give it the longest service life then you'll need to oversize it to something like 12-15 Ah size.
Your solar panel, ideally, has to provide at least that much energy every day plus account for inefficiencies in the charge process and the battery chemistry itself. Say you have to provide 4-5A (~50-65W) a day. Solar panels need good sunlight to really produce power so you have to position your panel for maximum light. Depending on the location this may vary wildly (from only a couple to several hours per day). Usually you oversize the panel to help day with less than ideal sun days. In this application I think a 30-40W panel would work.
In addition to my charger - which, of course, I'm proud of - and designed to be able to provide lots of data about how well the charging system was operating, there are a lot of cheap Chinese chargers out there that will also charge a 12V battery. The same ideas in selecting batteries and panels apply.
Anyway, I hope this at least has given you some food for thought.
