Author Topic: Best PCB Design tool for simple through-hole boards?  (Read 4423 times)
Offline Jon86Topic starter
« on: November 24, 2013, 11:53:28 am »
I've decided I want to get a couple of PCBs made, only something simple, just a through-hole headphone amp on a 5x5cm board. I'm going to get it manufactured from iTead studio because that's all I can afford, and I guess I can deal with the stupid lead times.  |O
Anyway more to the point, what's the easiest software to use for this? It's only going to be a few components, DIP-8, some caps and resistors, and some headers.
Sorry if this has been asked before, but I couldn't find any threads about it.
Death, taxes and diode losses.
Offline danb35
Re: Best PCB Design tool for simple through-hole boards?
« Reply #1 on: November 24, 2013, 11:57:35 am »
CADSoft EAGLE is probably the most popular choice for hobbyists, and DIPTrace is another that seems to be a bit easier to use.  Both have no-cost versions available for limited use.  KiCAD is a Free Software alternative.  There's a whole forum category for PCB/EDA tools, just scroll down a bit from the main forum page.
I've used EAGLE a little bit, and the interface definitely takes some getting used to, but it's very widely used, so there are lots of people who can help with it.
« Reply #2 on: November 24, 2013, 12:18:50 pm »
Thanks, I think I'll give DipTrace a go!  :-+
And sorry, I totally forgot about that category  |O
Offline filip_cro
  • Country: hr
« Reply #3 on: November 24, 2013, 12:21:54 pm »
Can free DIPtrace export gerber files?
Offline BravoV
  • +++ ATH1
« Reply #4 on: November 24, 2013, 12:33:52 pm »
CADSoft EAGLE is probably the most popular choice for hobbyists, and DIPTrace is another that seems to be a bit a lot easier to use.
Correction.  ^-^
Another vote for Diptrace if you dont want to spend alot of time and just want quick result and relatively good enough pcb application, and its free version is enough for small project, imo.
Offline kripton2035
« Reply #5 on: November 24, 2013, 12:54:25 pm »
yes free diptrace is only limited to 300 pins, and you can ask for a free 500 pins serial number by asking them.
Offline filip_cro
  • Country: hr
« Reply #6 on: November 24, 2013, 01:19:56 pm »
I like KiCad and I use it at home. I school we use Eagle (older version, 5.?) and I don't like it. I only hope that KiCad components library will grow, and KiCad become  hobbyist standard.
Did somebody of you use different cheap PCB manufacturers?
Online nctnico
« Reply #7 on: November 24, 2013, 02:01:07 pm »
I ordered some boards from Seeedstudio and they are OK. Delivery takes long though.
Offline Jon Chandler
    • Throw Away PIC
« Reply #8 on: November 24, 2013, 03:27:05 pm »
Here's an article that lists a number of PCB fab houses that I have used or know the quality of their work:
PCB Fabrication Sources
iTead, Seeed, Elecrow and ElecFreaks all offer essentially the same deals on 5cm x 5 cm boards and 10cm x 10cm boards.  Elecrow offers several colors of soldermask without an up charge, and also offers v-score panelization for a small up-charge based on the total number of boards per panel.
Check out the article and comments for the details and verify with each vendor's website as the deals change quickly.
Offline mcinque
  • I know that I know nothing
« Reply #9 on: November 24, 2013, 03:39:12 pm »
Diptrace  :-+
« Reply #10 on: November 24, 2013, 07:24:42 pm »
Great, thanks a lot!  :-+
Just a quick side question, are there any 3.5mm jack sockets included in the pattern libraries? I don't mind which one it is, as long as it's readily available on ebay or whatever :)
