The best
battery for deep cycle operation is the flooded type. True, they need maintenance, but at least maintenance is possible. With SLA batteries, you have no idea what is happening with the battery and it is never good.
Particularly for cycling applications, you really want flooded cells.
But then there is a problem! Flooded batteries are somewhat messy and the fumes given off during recharging are corrosive.
In the power industry, the circuit breaker trip mechanisms often run on 48VDC (or 120VDC) and the power will be provided by flooded lead acid batteries. In the nuclear industry, the batteries have a glass housing so visual inspection for sulfation is possible.
In the janitorial market, there are floor buffers that use flooded lead acid batteries. The Trojan series seems quite common:
https://www.trojanbattery.com/markets/fm/6v/These flooded batteries are fully cycled every day and last for years.
Alas, I have no idea what might be available in Lebanon.
