Author Topic: Best way to switch capacitor for coilgun  (Read 7117 times)
Offline smashedProtonTopic starter
« on: November 15, 2013, 09:36:40 pm »
Hello all.  From the title it's pretty much self explanitory.  What is the most proper modern way to switch a giant capacitor into a big inductor.  I know to have a free wheeling diode to protect against reverse emf if I'm using a transistor.  Is an scr the best way to do it?  SCRs are awefully expensive...  What about a capacitor supressed relay?  Would the contacts still flash over and weld together?  That wouldnt be good...  Thanks in advance
http://www.garrettbaldwin.com/
Invention, my dear friends, is 93% perspiration, 6% electricity, 4% evaporation, and 2% butterscotch ripple.
Offline c4757p
  • adieu
Re: Best way to switch capacitor for coilgun
« Reply #1 on: November 15, 2013, 09:58:00 pm »
Must be those solid gold ones... ???
Online Zero999
  • 0999
« Reply #2 on: November 15, 2013, 10:04:43 pm »
An SCR with a high enough current rating might be expensive - I haven't checked though.
Online nctnico
« Reply #3 on: November 15, 2013, 10:44:02 pm »
Did you look into a spark-gap?
edit: I looked a bit further. If the voltage is high enough then a triggerable spark gap is definitely the way to go. It is much more robust than a thryristor and costs very little.
« Last Edit: November 15, 2013, 11:12:10 pm by nctnico »
Offline gotvolts
  • Got Volts?
    • Home of the most exciting kits on the planet!
« Reply #4 on: November 15, 2013, 10:59:58 pm »
What voltage and how much capacitance?
High Voltage and Tesla Coil Kits, Audio Modulation, LED and Lighting Kits, and more!!!
http://www.easternvoltageresearch.com
Plasmasonic Solid State Commercial Tesla Coil
Offline fcb
    • Electron Plus
« Reply #5 on: November 15, 2013, 11:04:02 pm »
An SCR would be the ideal way to do it.  I would suggest an IGBT or two, but it wouldn't be any cheaper.
What is your peak capacitor, capacitor capacity, and estimated peak current?
« Reply #6 on: November 16, 2013, 04:33:09 am »
It's going to be multi-stage, that is why I need the electronic switching.  Each capacitor is going to be at 350 volts and 3700 uF.  227 joules per capacitor. Very very fatal if I get shocked by it...  I understand the safety, and have played with it before.
« Reply #7 on: November 16, 2013, 07:22:28 am »
Look for old forklift SCR packs and use the hockey puck ones as the SCR's. With a low repetition rate you will not need the 20kG of heatsink they typically have bolted to them, just a pair of polished steel plates clamped across the ends with a thick copper wire bolted to each end. Those should handle the current with little problem provided you have enough gate current to switch it on very fast.
Offline staze
  • I _might_ have a problem...
    • Everybody Staze...
« Reply #8 on: November 16, 2013, 08:16:59 am »
IGBT's are what modern strobe camera flashes use... they probably could handle the current, and might be easier to control (not positive on that). Though, they're probably more expensive.
“Give a man an answer, he’ll keep his job for a day. Teach a man to Google, and he’ll be employed for a lifetime”
Offline G7PSK
  • It is hot until proved not.
« Reply #9 on: November 16, 2013, 10:02:43 am »
If you have really high currents and highish voltage ignitrons are very robust which is why they were the choice for spot welders before solid state came in. I used to have a Sciaky spot welder which had two in tha could switch several hundred amps at 415 volts over a fraction of a cycle that was on the input side the conductors were about 40mm by 15 mm solid copper bar. The output was 2 copper plates 20 mm thick with a hole in the middle and a slot.
Online Psi
« Reply #10 on: November 16, 2013, 10:20:11 am »
*Psi takes one step back  ???
Exactly how many of those are you going to have in series?
« Last Edit: November 16, 2013, 10:23:26 am by Psi »
« Reply #11 on: November 17, 2013, 05:18:06 am »
Two in parallel for the first stage, then one for each subsequent stages.  A total of 6 capacitors.  The coilgun would be mounted on a tripod, so the capacitors wouldn't be anywhere near my face
Offline Marco
« Reply #12 on: November 17, 2013, 07:34:10 am »
At those kind of voltages the currents for a discharge in the 10 msec range are actually not that high, less than a kA, which is pretty low for SCRs. You don't even need hockey puck or even stud devices since the repetition rate is low. A SCR in the 5 buck range can handle that.
Since you are talking about a 100 buck capacitor I don't see why you are calling the SCRs expensive ...
« Reply #13 on: November 17, 2013, 08:26:15 am »
I got the caps for free.  I was also wrong about the price of the caps.
Offline Marco
« Reply #14 on: November 17, 2013, 09:35:44 am »
Still, do you consider say the  VS-70TPS12PBF expensive?
