I'm trying to integrate a 4 pin TRS plug with my Android smartphone and cannot get it to recognize the jack.
I thought it was based on a small microswitch inside the plug but it seems it is actually based on some resistance. On my RAZR, pin 3 (ring 2) is the common/ground connection, pin 4 is the microphone.
I've tried putting 220 ohm from any output/input to ground and tried also with 1k, shorting pins in all combinations.
Measurements on the original headphone set shows 1.5k mic-gnd, 330ohm out-gnd.
The easy way would be to buy another headphone set and tear it down but I'm sure I'm missing something and it should just work, given that in general headphones vary widely.
