For a hobby project (which will hopefully be of interest to a few others, so should be reasonably easy to build) I am looking for a bi-color LED to indicate battery charging and power-on state. The two LEDs can't share any terminals: One sits between the external power supply and the charging IC's "charging now" output, the other between the switched internal supply voltage and ground.
While I found various bicolor LEDs in SMD packages which bring out the two anodes and two cathodes separately, I came up empty looking for THT parts. Has anyone come across such a beast?
I would prefer THT since it gives me more flexibility in positioning the LED, bringing it to the same height over the PCB as the switch and jack next to it. (It would be bent 90° to face a side wall of the enclosure.) I could use an SMD LED with an angled light guide to bring the light out to the side, but the off-the-shelf light guides don't have the right heights.
Any other ideas? Have you been successful making your own 90° light guides, so they could be "cut to size"? (I have used straight polycarbonate rods with good success, but assume a sharp bend will make them lose most of the light.) Maybe there are off-the-shelf light-guide prisms which can be glued to the enclosure instead of being mounted on the PCB, so they sit at the desired position? Or some DIY solution which uses two separate THT LEDs and combines their light?
Many thanks for your input!
