Author Topic: Yamaha AS-701 phono input capacitance?  (Read 672 times)
Offline hifinerdTopic starter
« on: April 21, 2024, 06:10:16 am »
I have a Yamaha AS-701 integrated amp (same as 801 except the DAC).  Some MM phono cartridges are picky about the maximum capacitance; Audio Technica cartridges are said to work best with C at or below 200 pF.  I didn't want to order the service manual just for this.  Do any of you know the exact phono preamp input specifications?  Thanks in advance!
Offline moffy
Re: Yamaha AS-701 phono input capacitance?
« Reply #1 on: April 21, 2024, 07:23:18 am »
The RCA shielded cable should be the source of most of the capacitance.
« Reply #2 on: April 21, 2024, 11:49:33 am »
I have a very low capacitance set of phono interconnect leads.  I was hoping someone here had a service manual and could look up the specs or look on the schematic.
Offline CaptDon
  • Country: is
« Reply #3 on: April 21, 2024, 04:08:00 pm »
schematic download online?
Offline wasedadoc
« Reply #4 on: April 21, 2024, 04:24:02 pm »
The Service Manual is available online. Gratis from at least one source.
