The 450V is the DC peak after rectification.
Then you'll have to figure out what the loaded voltage will be. If it needs to stay near 450V then the conduction angle will be very low and the RMS-to-average ratio will be very high. The DC-DC converter will have its own input filter and energy storage so you may not have full control over this. Since efficiency apparently isn't a super-high priority I'd suggest a low-value ballast resistor on the output. Regulation by dissipation works!
Generator motor will be at less than half rated power. Load is a dc-dc converter (that I'm not responsible for) who's output will always be less than I'm generating.
That certainly helps as you only have to make sure the power factor and related parameters are not too extreme. I don't think the voltage drop across the rectifiers will be a big factor in efficiency or heat dissipation so I'd suggest something that is isolated and easy to heat-sink. Perhaps several of the modules suggested by
moffy in parallel would be good. You might consider RC snubbers for the rectifiers because this setup might generate some pretty serious noise.
Regulation and ripple and all that does not have to be tight. Super low converter performance requirements on this one.
The fact that it's 3phase and 800hz should result in lower ripple from the generator, and reduce the capacitor requirements.
That's good and bad. Using a smaller capacitor and allowing some ripple on the output will increase the conduction angle, that's good. However you still have to take the input of the load device into account and I assume that is an unknown at this point, that's bad. The aforementioned ballast resistor might need to be loosely specified now and precisely determined later. 3Θ @ 800Hz will help reduce
voltage ripple for a given output filter but the ripple
current will be a monster. You'll likely need to look at DC link film capacitors and probably ask a manufacturer or two for guidance.
