After spending some time I finally realised why the earlier circuit is stupid. There are several reasons, but the biggest is the biasing decreases the differential voltage and hence will make me use a better opamp with lower Vos.
I have updated the circuit to the one in this post, its a better one. I plan on using OP07 opamps for this (not my opamps of choice, I just don't want to order parts from digikey).
OP07 have a Vos of 30uV so it makes perfect sense to use in the input stage. With a shunt of 10mΩ, I can measure a minimum current of 3mA. Dividers will decrease the common mode voltage by half but also the differential voltage so 3mA becomes 6mA. Still perfectly acceptable. The amplifier has a gain of -20x with bias voltage at VBAT/2
I have a 12b ADC on my MCU (STM32G0), so at a reference of 3.3V I can measure in steps of ~800uV, which translates to ~4mA of current across the shunt.
Sorry if this is all scattered and confusing. Hopefully the image is easier to understand. Not really thinking in terms of decent quiescent current right now, that comes later.
