Basic PChan needs a + gate V to turn it off.
So select a FET with a Vth that meets your logic level out of the CMOS gate. If you
need inversion translate your AND-OR to NAND-NOR logic and or use the inversion
in the NAND-NOR to invert any signals to meet the logic requirements. But you have
to raise the gate to Vth + Vs. Without seeing the rest of the power domain schematic
I cannot tell whats driving use of the PFET.
Worst case you can always use a charge pump to get extra gate drive, or a diode
multiplier off CMOS grunge oscillator circuit.
http://electricalengrz.blogspot.com/2013/05/aoi-logic-to-nand-or-nor-logic.htmlhttp://stackoverflow.com/questions/9845684/how-to-convert-a-boolean-expression-from-and-and-or-to-only-nandOne alternative is use of a low end UP, like a PSOC 4000 series part,
use it to do the sequencing and logic, then a more simplified interface
to actual power routing components should be achievable. Sleep mode
would enable power conservation as well. Like a 4013, << 50 cents.
Has internal reference and comparator.
Regards, Dana.
