Author Topic: BLDC controller overcurrent protection?  (Read 1665 times)
Offline ifonlyeverythingTopic starter
« on: May 03, 2022, 11:43:44 pm »
Kind of a broad question here but I'm working on a BLDC controller project. I'm using the ST L6234 for the power stage. I want to have inline (motor phase) current sensing and overcurrent protection. I plan on using the ST TSC2011 current sense amplifier. I've seen other current sense amplifiers with integrated overcurrent signaling but they're very difficult to get due to the semiconductor shortage. The MCU I'm using does not have an onboard comparator so that is also not an option.
Anyways, how is overcurrent protection a BLDC driver typically implemented with discrete components? Does anyone have a sample schematic that they could share? I imagine it's a comparator on the current sense amplifier output but I'm not sure what kind of filtering is required, or how fast of a comparator is needed to protect the power stage MOSFET.
Offline Doctorandus_P
Re: BLDC controller overcurrent protection?
« Reply #1 on: May 04, 2022, 12:11:23 pm »
MOSfet's are quite robust for over currents during short times, and if you're already measuring motor current with a sense amplifier, then doing overcurrent protection in software is good enough for anything except a hard short in the wiring.
There are also no hard limit on motor current for motors.
A lot of motors can be safely overloaded (Doubling the current is quite common) for a short time (upto a minute or so) to get burst of power out of them.
This is often used for example during acceleration.
The limit is the themperature that the motor has reached, and it takes quite a while to heat up.
A temperature sensor (and software) is a good way to make a motor + controller combination more reliable.
In industry (3-phase induction motors, from small to many kW)  it's common to have motor protection switches.
These switches tend to have a relay that opens the circuit at too high a current, and they also have bimetallic strips with resistance wire around them.
If there is too much current during some time, then the bimetallic strips heat up and also shut of the motor.
This can also be programmed in software by keeping track of the integral of the square of the motor current (heat generated by ohmic resistance) combined with a slow decay to match motor mass and cooling.
A real temperature sensor also works with an obstructed fan, while the software has no knowledge of that and that limits it's usefulness.
Some microcontrollers also have some extra functions in their ADC peripheral. They can for example generate an ISR if an ADC sample is above a preset value.
« Last Edit: May 04, 2022, 12:27:05 pm by Doctorandus_P »
Offline strawberry
  • Country: lv
« Reply #2 on: May 04, 2022, 02:32:15 pm »
short circuit some ~1..20µs including transistor speed
motor stall some ms
motor overload some s
