Author Topic: BLDC fan on unfiltered DC?  (Read 2056 times)
Offline c4757pTopic starter
  • adieu
« on: November 02, 2013, 01:17:23 pm »
I'm still working on repairing that HP 3437A - the fan is pretty much completely shot. Time for a replacement.
The original HP fan had three windings which they ran using a three-phase driver circuit on a rectified but unfiltered (not just no regulator - no capacitor) transformer tap. This sort of fan is pretty hard to find now (and expensive when you do find it), so I'd rather just put in a modern brushless (probably this one). Would it be unhappy without a filter capacitor? That's a pretty big cap (probably at least 1000uF) and I'd rather not have to find a place to stuff it.
Offline sync
Re: BLDC fan on unfiltered DC?
« Reply #1 on: November 02, 2013, 02:35:36 pm »
It doesn't work.
Btw: Is that 12V unreg. the RMS value? Then a cap alone would produce to much voltage.
  • adieu
« Reply #2 on: November 02, 2013, 02:45:36 pm »
The peak is just over 12V - it could easily average 12V with either a series resistor to drop a bit, or a slightly undersized capacitor. I just chose a 2200uF cap for it, so I'll go with the series resistor.
I just noticed that the service manual has a memo attached addressing this - the original fan was discontinued and they describe replacing it with a DC fan: direct replacement, disabling the three-phase oscillator, for some serial numbers, and adding a 22 ohm resistor in series for others. Nothing about a capacitor; they must have selected a replacement fan which doesn't need it.
« Last Edit: November 02, 2013, 02:49:24 pm by c4757p »
Offline sync
« Reply #3 on: November 02, 2013, 02:53:33 pm »
No need for the resistor. 12V fans can usually operate at 15V.
