So here are my Thermal Results
I ran the tests at Multiple switching frequencies 30kHz, 20kHz, 10kHz and a load current of 20A for all tests. The temperatures were allowed to reach steady state. Interestingly the it took quite a long time for steady state, around 15- 20 minutes which was more than I predicted.
This is my control an ambient temperature of toughly 23 degrees
30kHz:
Low side FETs
20kHz:
Low side FETs
High Side FETs
10kHz:
Low Side Fets
High Side Fets
Load Motor (Alternator) got very hot as can be seen ended up putting a desk fan on it and that dropped the temperature by a few degrees (to around 100)
I think the results are quite interesting, there is a major difference between the 30 and 20kHz frequency but roughly no difference between 20 and 10kHz. Also due to the low and high side FETs being directly on top of each other their temperature was practically identical. The phase wires also got warm, I guess they added as a heat sink as well.
The DC link capacitor got warm but nothing major.
Any thoughts?
