You're probably after "DCC" (double cotton covered) or silk (higher end) magnet wire. I went down this hole a while ago and I don't think it's been made for a long time. The old fiber wrapped wire had thicker insulation, larger diameter for the gauge, less turns per inch. Litz, TIW or maybe kynar wire wrap wire? My thought for an antique Tesla coil build and general old timey apparatus construction was to use heavier green enamel magnet wire and cover it in a less than high gloss varnish. I have seen emerald green DCC in a 20s kit TRF radio before.
1920 to 1940 covers a lot of development. If you're after the more open look with wood and brass the 20s is likely where you need to be.
Hookup wire is easier, look at radio restoration suppliers. Cloth covered or bare, tinned, "bus wire".
