Poll
How do you like F-Parts?
Oh dear, it is wonderful !!!
I like it and will use it
Bah..it's okay I guess, but I won't use it
Seen better ones (for free)
I will program a better one and prove it to you!
Author Topic: F-Parts: My new component organisation program  (Read 1313 times)
Offline RagerTopic starter
« on: March 08, 2017, 09:53:09 am »
Hey everyone!
I looked al over the internet and could not find a good component organisation program. So after quite some time I desided to Do It Myself  ;D
I think that it turned out quite well and I put a lot of work and time into it. For that reason I think it would be a waste to not share it:
https://github.com/RFgermany/F-Parts
I hope you like it!
Florian
Offline Zom-B
Re: F-Parts: My new component organisation program
« Reply #1 on: March 08, 2017, 06:08:55 pm »
Funny, because yesterday I was discussing about component inventory programs with a coworker.
There are some (e.g. partkeepr), but they all have in common that every part is exactly tracked, like if you have 457 of a resistor, you'd enter 457 and hope everyone updates it dutifully (not gonna happen). Moreover we experiment a lot so often parts are tried and put back, or not put back, or left on the tables until a cleaning round and then into the trash because they're cheaper than chopsticks.
What would be better than exact count would be a metric like: [none, very few, few, plenty, too much]. Then each part would have a flag 'keep stock' or something, and the program could compile a BOM of all 'keep stock' parts that have <= 'very few' in stock.
[edit] As for feedback:
  • Cool feature of adding files. Haven't thought of that before.
  • Add context menu for categories/tree editing instead of buttons,
  • Allow add/remove columns, because I won't need Vmin/Vmax but would like 'Package',
  • Add Search Add Ctrl+F shortcut
  • Add Parametric filter
  • Add a picture column that shows as a micro-thumbnail and zooms when clicking (see image of a program I once made). Kudos if it automatically finds missing images on common shop sites.
« Last Edit: March 09, 2017, 07:06:48 am by Zom-B »
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: March 08, 2017, 07:36:50 pm »
Hmm, interesting. :)
...But with a name like that, why didn't you go for simply: "Farts"?  ::) :horse: ;D
Seven Transistor Labs, LLC
« Reply #3 on: March 08, 2017, 09:36:45 pm »
Hey there and thanks for the feedback!
It is the first time for me to program something like that, so there is l lots of room for improvements. Maybe I find time to implement some of the ideas 😄 By the way. Columns ( properties) can be added, removed our renamed with the add, remove, rename properties buttons. And parts can be filtered by the search bar I the upper right corner :D
Best regards,
Florian
