Author Topic: psu regulator ic supply  (Read 564 times)
Offline m3vuvTopic starter
« on: March 12, 2022, 09:36:42 pm »
Hi all,i am building a bench psu (variable),the transfo is from a palstar ps-30 psu,it has an auxillary winding,i plan on using that to power the regulator ic(infinion sg3532)
I have a couple of questions
A,am i best using a 78 series regulator to power the ic?
B,can it be a lower voltage than the main psu output?
TIA.
Re: psu regulator ic supply
« Reply #1 on: March 13, 2022, 07:44:29 am »
can no one advise on this?.
Offline inse
« Reply #2 on: March 13, 2022, 09:17:46 am »
All the application drawings in the datasheet have the IC (Linfinity, btw.) supplied by the input voltage.
If you look at the block diagram, you will notice that the driver is tied to the Vin and thus cannot drive a highside transistor above that voltage.
If you plan on using a PNP, you will encounter a low voltage limit.
The following users thanked this post: m3vuv
