An interesting question. As you have 415V available, then in principle the easiest way to get your power is to use a conventional, small xformer with a 415V (or 240V P-N) primary. I presume that you either can’t or do not wish to make direct electrical connection, hence your interesting idea of using a ‘current xformer’.
It should be possible, given you only need 20mW of power. I haven’t thought through in detail, but it seems that the first step is to produce a design that can provide your desired voltage (3.3V) and power (20mW) at the minimum available ‘primary’ current, say 1 amp or even less of you can do it. Then, you need to think about what needs to be done to keep things under control at 500A primary.
Presumably you will use a slit core of some sort,
or can you thread the 500A conductor through a non-split core? Either way, we are presumably talking about a toroid, or ‘rectangular toroid’ kind of core shape, with the 500A primary passing through the hole in the middle of the core. I would use the smallest core that gives enough space for the primary conductor, plus your secondary wnding. For example, if we talk toroid shape, maybe something like a 30mm hole in the middle, with a cross sectional are of magnetic material of around 15x15 mm. In principle it could be laminated iron or ferrite, but for now I’ll talk as if it was iron.
Next part of the design process it to estimate how many turn-per-volt you will be operating at, and this is determined by the cross sectional are of the magnetic circuit, the frequency, and saturation flux density of the magnetic material, according to the formula :-
N/V = 1.414 / (6.28 x f x A x Bpeak)Plugging in f=50Hz, Bpeak=1.8 Tesla for steel and A=20x20mm = 0.000225m^2 gives :-
N/V = 11.1 turns/volt
As N=1 on the primary, this sets the primary voltage at 0.091V, above which the core will saturate. The saturation flux density of ferrite is lower than for steel, maybe 0.5 to 1 Tesla depending on the ferrite, but just plug it into the formula above to get your turns/volt.
If, for example, you want 5V RMS on the secondary, then the required number of turns in this example is 5 x 11.1 = 55 turns.
As the xformer goes into saturation, it will provide a bit more that your design voltage, and for fast spikes/transients it can produce MUCH more voltage, so it is up to you to provide suitable voltage clamping on the secondary, by way of back-to-back zeners, transient voltage suppressors or whatever.
As with any current xformer, the secondary voltage will be whatever your circuit across the secondary defines it to be, but ultimately limited by core saturation at about (1/6.25) volts/turn, for this example. If Ip=1.0A, then a resistive load of 0.091 ohms on the primary will give Vpri=0.091V, as per our design target. In this example, the turns ratio is 55:1, so the impedance transformation ratio is 55^2 = 3025. Therefore, a resistance of 3025x0.091 = 275 ohms on the secondary will ‘look’ like 0.091 ohms on the primary, and will limit the primary voltage to 0.091V, and the secondary voltage to 5.0V. The maximum power that can be input to the primary is 1.0A x 0.091 = 91mW, enough for your stated need of 21mW. Losses aside, this must of course be the same as the power delivered to the secondary, namely 5x5/275 = 91mW. The numbers have to add up, and they do.
You will be relying on core saturation to limit the maximum voltage that is developed on the secondary for primary current above 1A. In theory, a current transformer produces an infinite secondary voltage if the secondary is opened.
If it was me, I would grab the proposed core, pass a 1A AC current through a primary conductor passing through the core, and see exactly what comes out of the 31 turn (or whatever) secondary. First make sure you can get the voltage and power that you need on the secondary, at 1 amp primary Then crank up the primary current to 5A, 10A etc to whatever AC current you can reasonably produce, and see what happens.
The actual behavior is complicated by the large and unknown leakage inductance of the single turn primary, that may limit the power you can actually draw from the secondary, at low primary currents. Probably this can be minimized by looping the primary conductor in such a way that it completes a nice, proper single turn.
Because you don’t really know your leakage inductance, and you probably don’t know the exact saturation characteristics of your core, my gut feeling is that modelling, and/or using the formula above will only be a guide to actual performance and behavior, which is why I recommend trying things out on the bench. Even so, I reckon that the formula and general approach that I have described will make a good starting point.
I have many cores lying around, plus can easily produce variable AC current up to 20A or so, so might ‘play around’ and see what happens, see if what I’ve said above is nonsense or basically right.
