Hello to everyone and happy new year!
I´ve made a design with Bosch´s BNO055 for a handheld device, unfortunately as the title suggests I get a horrifically high current draw when in suspend mode.
The design is textbook, same as the one suggested by Bosch in their datasheet.
PS0 = 0V, PS1 = 0V, ADD = 0V, bootloader inditor pin shunted at 0V (as indicated by datasheet, but later found out it is wrong, on their forums)
I know the add pin has a weak pull-up, I removed the address pin to ground, no change (address changed normally so I would guess it´s not my soldering)
I also dug out the bootloader pin, again no change.
In between I changed also boards and IMUs to be sure that either is shot by a bad connection. Still the same...
I also changed the suggested internal regulator value from 100n to 1u as indicated, still no luck.
I am at a loss as of what might be the problem. The suggested current consumption when in suspend mode is 40uA, having 3 times as much is a bit unacceptable,
as it brings the battery life from 5 - 6 months to barely 1.5 months at stand-by. (the rest of the board consumes 9 - 10uA when in suspend mode).
I am currently starting to suspect a batch problem as many other people have reported same issues on Bosch´s forums:
https://community.bosch-sensortec.com/t5/MEMS-sensors-forum/High-current-consumption-of-BNO055/td-p/8364Still, If anyone has any idea on probable causes of the problem, it would be quite helpful!
Thanks a lot in advance!
Lefteris
