Author Topic: Board to board connector  (Read 1816 times)
Offline DaxxinTopic starter
« on: January 14, 2019, 07:11:49 pm »
need to connect 2 boards , actually my kicad project, in vertical like a sandwich , any hints for connector 50 pins(2x25) through hole
that keep the boards atleast 2 inch space (connector pcb1 - extender connection  - connector pcb2) ?
Offline soldar
Re: Board to board connector
« Reply #1 on: January 14, 2019, 07:18:27 pm »
How about using ribbon cable with IDE-type connectors?
« Reply #2 on: January 14, 2019, 07:46:39 pm »
Hi , no need to disconnect and save space too , inside pcb area
something like this ..but more space :
« Last Edit: January 14, 2019, 07:50:15 pm by Daxxin »
Offline DaJMasta
    • medpants.com
« Reply #3 on: January 14, 2019, 07:54:23 pm »
There are lots of options for this.  You can go with traditional headers like those, if you need higher density than normal 2.54mm headers, you can go to the half size, 1.27mm which is still pretty common.  You can also look into mezannine connectors, which are what are typical for very low profile, high speed board to board interconnects.
Maybe have a search around digikey or your preferred distributor to see what is available and then look around to find the best price.
Offline KL27x
« Reply #4 on: January 15, 2019, 01:51:04 am »
FPC ribbons and connectors go up to 80 pins and beyond, and down to as little as 0.2mm pitch. They can get pricey at the smaller sizes. Probably not what you had in mind, but in case you're ever in a pinch.
Offline Richard Crowley
  • KJ7YLK
« Reply #5 on: January 15, 2019, 02:06:29 am »
Does the connector need to be structural, or just provide connectivity?
IOW, will there be separate means of holding the boards, and maintaining their separation distance?
What are the board real-estate constraints?  Can you afford standard 0.1 inch pitch (2.6 by 0.3 footprint)?
How much movement and/or vibration does it need to handle?
Offline wictor
« Reply #6 on: January 15, 2019, 01:53:23 pm »
PCI Express connectors on both boards and pcb with traces between connectors.
Well, if you don't need to disconnect, just make rectangular slot to both boards and route signals to the slot edge. Then make connector pcb between those boards with traces and solder together.
Wictor
« Last Edit: January 15, 2019, 01:58:36 pm by wictor »
