Author Topic: Custom or special IR LED manufacture?  (Read 1016 times)
Offline alanambroseTopic starter
« on: July 23, 2019, 10:45:20 am »
Does anyone, by any chance, have any experience of custom LED manufacturing & manufacturers? Ideally I need two IR LEDs, with different wavelengths, say 740 & 855nm, in one smallish package, say 0603. Regarding economics: this would be in smallish quantities, say 10,000s initially, but for a high-value biomedical application.
TIA, Alan
“A foolish consistency is the hobgoblin of little minds"
Offline KIKi
  • Country: hr
Re: Custom or special IR LED manufacture?
« Reply #1 on: July 23, 2019, 11:06:24 am »
You could try Refond http://www.refond.com/  :)
« Reply #2 on: July 30, 2019, 09:01:04 am »
FYI for anyone else coming across this thread / searching for similar parts: Ushio has off-the-shelf some multi-IR LEDs and also a custom build service e.g.
http://www.ushio-optosemi.com/en/products/led/std/multi/smt_family.html
and
http://www.ushio-optosemi.com/en/products/led/std/multi/cma_family.html
« Reply #3 on: July 30, 2019, 10:55:38 am »
Also any leads on custom LED manufacturers / dies / bonding in relatively small quantities (say 100K units) would be great. Similarly, Asian-based reps who can search the Chinese market and custom manufacturers (e.g. Everlight, Lite-On, HARVATEK, OptoSupply, Meihua, Tonyu, Ekinglux, Oweis Lighting).
TIA, Alan
« Last Edit: July 30, 2019, 10:58:27 am by alanambrose »
Offline Zero999
  • 0999
Offline jmelson
« Reply #5 on: July 30, 2019, 06:47:09 pm »
740nm is much less common. I've managed to find one in the larger 1206 package but it isn't cheap.
Off the shelf is going to be WAY cheaper than having a custom semiconductor fabricated to your spec!
Jon
