TLDR; I pretty frequently find opamp data sheets without satisfactory detail about input impedance and/or bias currents. Why do vendors sometimes leave out this kind of critical information? Do they just not know it? Or do they assume that if you're a big enough customer you can ask them the question directly? Or they just assume it won't matter for most use cases? Any ideas?
Specifics:
I've been working with the AD8337 variable gain chip for some ultrasonic RX circuits. It consists of one uncommitted op-amp that is then fed into the variable gain stage. What is frustrating and confusing is that they don't specify the input impedance of that uncommitted op-amp, nor the bias currents, at all in the data sheet!
Because I am working with a single rail supply, I need to AC couple my input signal into the midrail which is 2.55V. So I decided to use two 100kΩ resistors to form a divider and then AC coupling through a 1nF capacitor. The value of these resistors is just a guess since I don't know the input impedance of the op-amp. When I actually come to build this circuit, I find that the bias voltage is about 2.8V instead of 2.55V due to the input impedance/bias currents of the op-amp.
After a bit more googling, I found a help topic stating that this uncommitted op-amp should match the behaviour of the AD8001, which has an input resistance of 10MΩ on the non inverting input and a bias current of up to 6µA. This can explain the 250mA discrepancy is voltage, since a bias current of 6µA would create a 300mV offset to a 50kΩ output resistance (2x 100kΩ resistors in parallel).
So yeah, going back to the TLDR, why don't they bother to include this information?
