Author Topic: Boost Buck DC-DC Converter  (Read 4079 times)
Offline bilkoTopic starter
« on: June 12, 2011, 11:42:19 pm »
Any experts here any DC-DC converters. I've been looking for info on a boost buck converter to run from a car battery and provide 12V DC, low noise at up to 10A output. What is the best way of achieving this ?
Input voltage 10-15VDC
Output voltage 12VDC
Output current around 10A
Efficiency > 90%
The converter needs to be quiet as far as RF is concerned as it will be running at the same time as a hf transceiver
Most laptop chargers I've seen are boost converters and not suitable, they are very noisy as far as rf is concerned.
Appreciate any guidance on schematics or even finished product.
Offline sacherjj
Re: Boost Buck DC-DC Converter
« Reply #1 on: June 12, 2011, 11:55:32 pm »
You are looking for something like a Single-ended primary-inductor convertor.  I'm not sure how easy it will be to clean up the RFI.
http://en.wikipedia.org/wiki/Single-ended_primary-inductor_converter
http://www.national.com/an/AN/AN-1484.pdf
Offline Psi
« Reply #2 on: June 13, 2011, 01:49:20 am »
I have one of these powering my VIA micro atx car computer.
It works well for me, never had any problems with it.
i dunno how much rf it puts out though
    High Output Current (12A Typical, 15A Peak)
    Wide Input Voltage Range (6-24V operating) (8-16V full load)
    Extremely Efficient (>95%)
    No Load Operating Current of < 70mA
    Sleep Current (All Rails Off) of < 4mA
    12.0 Volts +/- 2%
    Small Profile (1.9” x 3.5” x 0.75”)
    0.25” Spade Faston Connectors
    On/Off Jumper Header
    Fuse Protection
    Reverse Voltage Protection
    Load Dump Input Protection (Over Voltage)
    Short Circuit Protection
    Power On LED
    Very Low standby power (100 uA Typical)
    Does not “Brown Out” during Engine Crank
    Fast Transient Response
    12V Fan Connector
    Adjustable Output
Can get them here..
http://store.mp3car.com/DSX12VD_140W_DC_DC_Regulator_p/pwr-025.htm
More info..
http://www.mp3car.com/products/DSX12VD/DSX12VD_Manual.pdf
All the serial port codes to monitor/change settings can be found in this user manual for a slightly different model..
http://www.mp3car.com/products/DSATX/DSATX_Manual.pdf
« Last Edit: June 13, 2011, 02:06:15 am by Psi »
« Reply #3 on: June 13, 2011, 03:21:24 pm »
Thanks guys for your help. You've put me on the right path, I'm sure I'll be able to find something now. Brilliant!
