The output traces seem way too thin and can drop a bit, but not to 0.75V.
Did you probe at the cap at the output of the DCDC?
Looks like the DCDC is not able to get into PWM mode. Can you check the waveform at the inductor to check if it is in PWM mode with high current.
compare with the datasheet curves.
Can you force PWM operation?
