Author Topic: BR-2/3A Battery Replacement  (Read 1121 times)
Online bostonmanTopic starter
« on: August 09, 2022, 01:05:52 am »
I have a piece of equipment with a dead BR-2/3A 3V battery with solder tabs (solders to PCB) used to keep settings in memory. From memory, I'd estimate the battery is twenty-years-old, so it's not getting depleted quickly.
I'm finding some quite steep prices for these and wondering if the cost is due to the battery power or its unique style.
If it's just the style, does anyone know of a cheaper replacement that would be more cost effective?
Offline TheMG
Re: BR-2/3A Battery Replacement
« Reply #1 on: August 09, 2022, 01:39:41 am »
https://www.digikey.ca/en/products/detail/panasonic-bsg/BR-2-3AE2SP/64350
They're $5.46 in one-off quantity from Digikey, which is really not that bad at all, considering they have about 5x the capacity of a CR2032.
« Reply #2 on: August 09, 2022, 01:57:50 am »
I should have added that DigiKey has them cheaper than Amazon, which I found very odd.
I mainly asked because I wanted to confirm that I wasn't wasting my money when I could buy something compatible that's cheaper.
Offline alm
« Reply #3 on: August 09, 2022, 09:29:19 am »
Any primary Lithium 2/3 A 3.0V cell with solder tabs or wires should work. BR-2/3A is just the Panasonic name. $5 is the ballpark price I would expect to pay.
Offline tooki
« Reply #4 on: August 09, 2022, 05:46:46 pm »
It shouldn’t. Amazon’s pricing on electronics parts aren’t usually particularly good. (When they are, there’s a good chance they’re fake.) An ever since Amazon reimagined itself as a flea-riddled bazaar, it’s full of vendors, some of whom try to charge usurious prices for items there aren’t many listings for.
Offline tooki
« Reply #5 on: August 09, 2022, 05:48:58 pm »
Just a reminder that the voltage matters: this size battery exists in two different chemistries, one at 3.0V, the other at 3.6V.
« Reply #6 on: August 09, 2022, 05:55:42 pm »
I'll plan to order them from DigiKey (although the price was a no-brainer).
I'm trying to think if I need anything else before I spend money on shipping. Twice I got bit because I placed an order, and later realized I needed other stuff.
Offline TheMG
« Reply #7 on: August 09, 2022, 06:40:25 pm »
I've done that myself, multiple times...
« Reply #8 on: August 09, 2022, 06:50:18 pm »
I think if you create a user account, then you can add after submitting an order, but not certain.
One time I sent an email asking to add a component and they responded after my order got shipped stating it was too late.
