Methylene chloride, or heat ("Fire... and lots of it!" -- Dr. Hibbert).
Is it not sufficient to measure the wire diameter, count what turns you can see, and fill in the blanks, or just saw one in half and count by eye?
I imagine FEMM has a uniform current density attribute which would do an excellent job of simulating the overall behavior of a motor; you could even skip the stator altogether and use B-field source directly on the faces.
