Author Topic: brownout on MCU's  (Read 19600 times)
Offline jahonen
Re: brownout on MCU's
« Reply #50 on: July 26, 2010, 05:28:41 am »
Well, the simulation does not look very promising, "check"-circuit works just fine (just to show that TL431 SPICE macromodel works).
Regards,
Janne
Online Zero999
  • 0999
« Reply #51 on: July 26, 2010, 08:06:21 am »
Why is it not working?
It will work, it's not working because I made a mistake on my schematic, can you guess what it is?
Hint: I missed out a component.
Look at the datasheet for the TL431 and the LM431 for more information.
I'll tell you in a day or so, if no one can figure it out.
« Last Edit: July 26, 2010, 08:25:22 am by Hero999 »
Offline jahonen
« Reply #52 on: July 26, 2010, 08:40:36 am »
It misses the usual B-E-resistor which is needed to bias the TL431 correctly.
Regards,
Janne
Online Zero999
  • 0999
« Reply #53 on: July 26, 2010, 09:33:07 am »
Yes that's it. The TL431 will pass a small current when the voltage is below 2.495V so without a pull up the transistor will turn on before it should.
